Conversion of binary and decimal into Two’s Complement
Share
Two’s complement is used widely in binary related problems deals with zero and one only. In this article, we will discuss two’s complement along with arithmetic operations on two’s complement.
What is Two’s Complement?
Two’s complement is a mathematical operation on binary numbers and is an instance of radix complement (10’s complement). It is utilized in computing. Two’s complement is a technique of setting integers in order thatnot unusual place math issues come to be easy to implement. Two’s complement is a method that encodes nice and poor numbers in a binary variety representation. In the case of nice numbers, zero is with inside themaximumsizeablerolewhilst in the case of poor 1 is with inside themaximumsizeablerole. To get two’s complement of binary variety, first convert all of thezeros to one and all of the 1’s into zero in different phrases transpose that binary variety or invert that binary variety. After inverting the binary varietyupload 1 to LSB (at Least a significant bit). Two’s complement can be calculated for decimals and binary numbers.
Binary to two’s complement:
To get two’s complement of a binary number, first convert all the zeros to one and all the ones into zero. In other words, transpose that binary number or invert that binary number. After inverting the binary number add 1 to LSB (Least significant bit).
Example 1
Convert 00110010 into two’s complement?
Solution
Step 1:First invert the binary number
00110010 change into 11001101 after inverting
Step 2:Now add 1 in the LSB.
The two’s complement of 00110010 is 11001110.
Example 2
Convert 011100 into two’s complement?
Solution
Step 1:First invert the binary number.
011100 change into 100011 after inverting.
100011 + 1 = 100100
The two’s complement of 011100 is 100100.
Two’s Complement Calculator is a useful online calculator that can assist in finding two’s complement at one click.
Decimal to two’s complement:
The best way to discover two’s complement conversion is to start with small numbers of bits e.g., let’s start with 4-bits which can represent 16 decimal numbers range -8 to 7. 8-bit has a range of -128 to 127.
Positive integer
Example 1
Convert 9 to Two’s complement
Solution
Step 1:First of all, convert the decimal number into a binary number.
(9)2 = (1001)2
Step 2:Now invert the binary number.
1001 becomes 0110
Step 3:Now add 1 to LSB
                             0110 + 1 = 0111
The two’s complement of 9 is 0111
Example 2
Convert 36 to Two’s complement.
Solution
(36)2 = (100100)2
100100 becomes 011011
Step 3:Now add 1 to LSB.
                             011011 + 1 = 011100
The two’s complement of 36 is 011100.
Negative integer:
The negative number is formed by taking the positive number complementing it (bit-by-bit inversion) and adding 1 to the results
Example
Convert -7 to Two’s complement
Solution
Step 1:First of all, convert the positive number 7 into a binary number.
We have
(7)2 = (0111)2
0111 becomes 1000
                             1000 + 1 = 1001
We have the two’s complement of 7 is 1001
Step 4:Now invert the number.
1001 becomes 0110
Step 5:Now add 1 to LSB
0110 + 1 = 0111
Hence the two’s complement of -7 is 0111
Arithmetic Operations on Two’s complement
 We can add, subtract, multiply or divide two or more Two’s complements. Let us discuss them.
Addition of Two’s Complement
The addition of Two’s complement is just like binary addition. As 1 + 1 equals to zero and carrying one to the other term. 0 + 0 makes zero result. 1 + 0 or 0 + 1 gives 1 as an output. Let us take some examples in order to understand this concept.
Example 1
Add the Two’s complement of the following numbers
11001100, 11100011
Solution
Step 1:Place the addition sign between the numbers.
11001100 + 11100011
Step 2:Solve the addition.
   11001100
+ 11100011
  110101111
You can also use an online Two’s Complement Addition Calculator to solve such problems.
Example 2
11001111, 11101111
Solution
11001111 + 11101111
  11001111
+ 11101111
 110111110
Subtraction of Two’s Complement
Subtraction of Two’s complement is just like binary subtraction. As 1 – 1 equals to zero. 0 – 0 makes zero results. 1 – 0 gives 1 as an output. 0 – 1 can be done by taking a carry from other digits the carry will be 2. Let us take some examples in order to understand this concept.
Example 1
Subtract the Two’s complement of the following numbers.
11001100, 10100011
Solution
Step 1:Place the subtraction sign between the numbers.
11001100 – 10100011
Step 2:Solve the subtraction.
   11001100
– 10100011
   00101001
Example 2
11001111, 10101111
Solution
11001111 – 10101111
  11001111
– 10101111
  00100000
Multiplication of Two’s Complement
Multiplication of Two’s complement is just like binary multiplication. Let us take some examples in order to understand this concept.
Example 1
Multiply the Two’s complement of the following numbers
11001, 1010
Solution
11001 x 1010
Step 2:Solve the Multiplication.
  11001
x 1010
 00000
11001x
00000xx
11001xxx
  11111010
Example 2
100011, 1011
Solution
100011 x 1011
100011
x 1011
100011
 100011x
    000000xx
100011xxx
  110000001
Summary
Two’s complement is used for addition and subtraction to be done easily without any logic. Binary and decimals can be converted into two’s complements. Arithmetic operations can be done on two’s complement. This article is very simple. Once you learn the basics of this article you will be master it.
Discover more from TheFastr
Subscribe now to keep reading and get access to the full archive.
Continue reading
