Millions of people from all over the globe are dealing with skin problems these days. This is a real struggle that can get very frustrating over time, but you know what? There are many effective ways to prevent and treat these conditions, so keep on reading to learn more about them.
Here are the four most common skin problems you should know about, so check them out!
Skin problem #1: Acne breakouts
Acne is a very common skin condition among people from all across the world. For example, did you know that it is considered almost universal in teenagers, with a prevalence of 93.3% in people aged between 16 and 18 in Australia? That’s right, and even though it usually starts in puberty, it can affect adults as well. Apart from the face, acne can also appear on the back and shoulders. Acne breakouts happen your pores get clogged with sweat, bacteria, dead skin cells, and your skin’s natural oils. To prevent acne, make sure to always use a clean towel when washing your face. Sweaty clothes and headbands should be washed before you wear them again, too. When it comes to your skincare, be sure to switch to non-comedogenic products. These don’t contain oil or any other harsh ingredient, so they won’t clog your pores and worsen your acne!
Skin problem #2: Extremely dry and irritated skin
On the other hand, extremely dry and irritated skin is a completely opposite problem to a previous one. It causes your skin to be itchy and flaky, which can result in painful dry patches on the skin. You’ll know that your skin is naturally dry if it gets irritated even when the outdoor air is humid. Remember that the sun, pool, and air conditioning are the biggest enemies of your dry skin. Of course, your skincare routine must be adjusted to your skin type. A gentle face cleanser is an absolute must, as well as a moisturizer and face mask that intensely hydrate your skin. If you are in search of brand new products for your dry skin, make sure to buy Cemoy in Australia. These products will do wonders for your irritated skin and nourish it to the max, which should be your top priority!
Skin problem #3: Rosacea
Rosacea is another common skin condition, and it’s characterized by redness and flushing. It can sometimes cause pimples, pustules, and visible blood vessels on the face, too. It is good to know that there are several factors that trigger the symptoms of rosacea. The most important ones are stress, alcohol, hot weather, sun exposure, spicy foods, hot baths, and even certain medicines. Although there is no cure for this condition, there are numerous treatments that can put it under control. The most common ones incorporate creams and gels that contain antibiotics, brimonidine, and azelaic acid. On the other hand, laser treatment is a great choice for treating redness and visible blood vessels, as well as a swollen nose caused by rosacea. Of course, be sure to use sunscreen with an SPF of at least 20 all year round. It’ll minimize skin irritation and make your life much easier!
Skin problem #4: Psoriasis
Psoriasis is an inflammatory disease that manifests mainly on the skin. It affects women and men equally and it can appear at any age. Just like rosacea, there is no cure for psoriasis either; however, there are effective treatments that can help. Around 2.5% of the population in Australia is dealing with this condition. The affected areas are either red or pink and are covered with a silver or white scale. They are textured and most commonly appear on the knees, elbows, scalp, and behind the ears. Psoriasis typically causes itchiness and discomfort, but it can be relieved with hydrating moisturizers that reduce the build-up of scale and itch. Steroid creams are also quite common as they help reduce inflammation and thickness. The same goes for tar-based soap and other skincare products that can reduce scale and itch. Give them a try and you’ll see a fantastic improvement!
As you can tell, there are so many ways to prevent and treat common skin problems such as acne, dry and irritated skin, rosacea, and psoriasis. All you need to do is to stick to our tips and you’ll see amazing progress very shortly. Just follow the guidelines and you’ll make it happen, without a doubt!
